MUD DAWG
I'm curious if someone can help with this problem please.
A few months ago I had a brand new high efficiency Trane S9V2 installed, and the propane conversion kit was installed on it. I also had a propane tank installed on the property. The propane tank is a rental, and they gave me a 2 year old tank. No issues with the tank from what I can tell, but I'm wondering if it didn't have a bit of moisture in it?
For the past 3 weeks, we've been in a long and steady deep freeze, and my furnace doesn't want to fire. Before that, no issues at all. As it stands now, if the furnace goes off for even an hour, it won't come back when heat is called. I get no trouble codes on the board, I have no loose connections, no ice build up on the regulators, or any of the vent pipes.
The only way I can get the furnace going again, is to open it and use a hair dryer to warm it up a little. I run the dryer over the burners, and propane supply mostly. A few minutes later, it resets and fires away no problem. The heating company doesn't have an answer, but they're coming back to replace a pressure switch that seems to be sticking, but it might not be the issue. One way we've been getting by the last few days, is to disconnect the air intake, and just have the furnace draw air from the basement, but I know that's creating other issues and not a long term solution obviously.
Clearly something is freezing up and blocking the propane. But I'm surprised a brand new and high end furnace is experiencing this already and can't deal with it.
Any thoughts? I'm going through the manual now and see if I can dig something up, and deal with the issue once and for all.
Thanks
Thanks
