joseywales
I have a brand new Champion 8000W duel fuel generator that I only use with propane. New in March. Long way around the barn here, but I'm providing some background, leading to the question, which you can skip to at the end:
Fired it up in June, but it was a PITA to start. Using a regular BBQ grill tank. Finally, I disconnected the hose. Reconnected it and SLOWLY turned on the hose valve at the tank. BINGO! fired it up several times, consistently, just to test and let it run for 5 hours, powering our fridge, freezer, neighbor's fridge, etc.
Ok, so it needs a bit of a bleed, so the pressure is good to start. Fine. Even read online where guys recommend the same slow process. Fine.
Lost power again the other day, took a few clicks with the electric start, but it fired up an ran 5 hours, until the propane ran out (was not a full propane tank. Might have been the one I used on the first 5 hours). Anyway, I decide to change the oil. Now it won't start. Removed all electrical load, even disconnected the cords in case there's a mechanical shutoff when they're in place.
Turns over, even chugs a bit, then craps out.
- It feels like a fuel issue (Supply, choke, etc.). Or perhaps a shutoff - like the unit isn't level (not the issue) or, perhaps the oil pressure switch. It detects if pressure is low and shuts off the unit.
- Oil is filled and this hard start issue was in play when new, so either that switch was acting up as new, or another issue.
- Company is sending me a new tank hose (go from tank to the generator), which has the regulator. This is based solely by my description of the problem via email. Their phone tech support is swamped.
Is it possible/likely, that the generator ran the tank empty, so fuel was getting through, then wouldn't restart because something inside the regulator is now restricted? It just seems odd that it was letting fuel through fine, until the point where it ran out of fuel, then suddenly won't allow enough pressure. I've tried several tanks, with the same result.
I'm tempted to swap a BBQ grill hose/regulator, but the regulators look and are likely different? I'm thinking it's actually the oil shutoff switch, or something else.
