Propane or Electric?
homelessdespot
CT
Hi All, I have a 20ft x 20ft insulated attached garage (with insulated but drafty doors) I'd like to heat every once in a while to work in. Just enough to take the chill off, and only probably a few times a month for a couple of hours. It's usually around 40F in there all winter (Northeast).
I have a 1500watt electric oil filled space heater I could use but it's a little weak and takes forever to heat one side of the garage. Doesn't raise the temperature much.
Was thinking about getting a propane heater and running it off a 20lb tank for faster warm up times but do those create moisture problems?
Would I be better off with just a second 1500watt electric heater?
6768rogues
Western NY
Given your choices, I would use electric heat. The propane heater will give off a lot of moisture and that moisture will condense when you turn the heat off. For an electric heater, you could use a radiant type heater that is aimed at you while you are working or use a cube heater that has a fan. An oil filled radiator type is nice for continuous use, but, as you noticed, it will take a long time to warm up the space.
Chetter
Northern Ohio
For your doors, if you are talking about overhead doors with tracks, check out the green hinge system. I have those on my 2 garage doors and they work great at keeping the doors tight against the seals even in high winds. They are worth the price since I heat my garage 24/7 during the winter and I use a Mr Heater propane forced air heater.
PugetDude
Superstition Mountains, AZ
With operating costs at a wash, I'd go with electric. No flames, tanks, or lines to run. One installed, it's just set and forget. I know others have mentioned power outages as a problem, but you're not going to be out in the shop without power anyway.
Post pics of the installed heaters!
couch67
Ontario Canada
baseboards in a similar sized space, insulated, and for occasional heating was my choice 20 years ago and never regretted it. Compact, quiet, and very low cost installation.
ForceFed70
BC, Canada
I would not use a ventless gas heater. The condensation is horrible. Especially in your scenario where you turn off the heat after.
The cost of installing a vented heater is high and it's unlikely you'll see any return on investment.
Another vote for electric.
Bretny
Dutchess county NY
To add to the negative on ventless gas heaters. They can give you a terrible head ache. They are ether be warm and not breath or breath and be cold.
Fo that small of a building electric should be fine.
I also live in the northeast. Your not going to beable to run any decent size heater off a 20lb tank when it gets cold here. You will need a 100lb tank. A 20lb tank is only good to vaporize 18kbtu at 40* and we both know it gets alot colder than that here. Even a 40lb tank is only good to 31kbtu at 40*.
greenskeeper
PA
Do you have an electrical panel in your garage? Could you run a circuit for a 5k watt forced air electric heater? Northern Tool has one for around $100
Falcon67
Merkel, TX
I use this, and used it back when I had a 24x20 shop. Works good, doesn't run very much if the shop is insulated. I have a lot of propane in 30 lbs tanks - don't use it.
txvwnut
Bedford, Texas
I have both in mine. I use the propane to help get it to a comfortable temp shut it off and let the electric maintain it.
