northerngmc
I have a Superior Radiant, model GR45 http://www.superiorradiant.com/Products/ResidentialGarageHeaters.aspx that I installed in my garage this fall.
It has worked great until today. I was out painting my bench last night and had the heat turned up to 15 C and was quite comfortable. I went back out today at lunchtime to check on my paint and it was cool in the garage. The heater was not working.
The control module is blinking 3 times which indicates an "Ignition Lockout".
I am not sure what might have changed to have caused this. I went through the trouble shooting guide without any luck. I have propane and the tank was filled over a week ago. I checked the outside vent and the intake appears clear and when trying to start I can smell propane coming out of the exhaust. The propane valve on the appliance is getting 24V when trying to start.
I pulled the ignitor out and tried it and I am getting a spark.
Any idea what "Ignition Lockout" might be other than it won't start?
The current temperature is -24C but it was -38C last week and everything went well.
The only other thing is the inlet pressure. Maybe something has changed in one of the regulators and dropped the pressure to the appliance and I don't have the correct pressure. What tool do I use to check the inlet pressure?
