SuperD
Looking for suggestions and photos how you connected the piping to your propane two stage regulator. I will be using the 120 gallon type rental propane tank. I see most two stage regulators use 1/2 inch pipe thread on the outlet side of the regulator. I will be using a 50,000 BTU Big Max if that makes any difference and the tank will be on the outside wall of the building. I will pull the permit in the next few weeks, already meet the 3 foot and 10 foot rules for the tank location.
Did you use a flexible line from the regulator to your garage or do you use a union and line everything up to direct connect the schedule 40 pipe to the regulator?
Do you mount the two stage regulator onto the building with a 40 inch long pigtail from the tank, or arrange it to have the regulator under the hat on the propane tank?
Really appreciate the suggestions and photos!
