Propane tank-top heater knob
seagull369
Anyone know how to get this booger to turn? Been fiddling with it and can't figure it out... Does the propane have to be on 1st, maybe?
seber
Deep East Tx.
Usually push to turn but in this case there is a button in the middle. Never seen that before. What happens if you push it?
SeisMec
Beryl, Utah
I've seen similar where you pull up on the black knob and then turn - fairly stout spring - so easier when attached to a full tank.
seagull369
I pushed it, twisted it, bopped it, pushed the button while twisting (which feels like it might be stuck in the depressed position) and nothing. I've owned it since it was new and worked the last time I had used it, though that was a few years ago. It was sitting in a breezeway for a while but never really got wet. Maybe I'll give a few taps with a hammer
what is it for?
It's for one of these guys:
grissom
I am having the same situation with mine but it had been stored in a metal shed for 10+ years - maybe internal corrosion??
I have to use channel locks to open it to the desired setting but can turn it off by hand.
Not sure if spraying it with WD-40 would work or be safe so I have not tried that
PugetDude
Superstition Mountains, AZ
Take it off and hose it with PB Blaster or Kroil. let it soak for a day or two. That should loosen it up. Blow it out with air before putting it back on and trying it.
