Proper tecnique for welding outside miter joints?
KMinAF
Fairview Utah
On my latest project I have several miter joints that will need to be welded and finished smooth. Up to now I have "stitched" the outside of the joint then run a bead on the inside. Is there a better or different way to do this?
Ohmthis
Outside of Louisville KY
Wnat I like to do if I'm finishing the edge, is to leave a gap about a 1/16 or so. It lets you get full penetration and then when you finish the edge you are not grinding all of your weld off.
gerahead
. . . or bevel the edges to be dressed prior to welding. You'll get good penetration with plenty of flexibility to dress the welds to your liking. L8r
vintagespeed1956
RanchoCucamonger, CA
weld the inside first, and then the outside. keep the heat down & grind.
outside edge of a true miter is razor thin.
edit:
you can also try not doing a miter at all. cut & bend the corner.
kazlx
Tustin, CA
If you cut your material to length minus 2 times the wall thickness, you can 45 the ends and have a nice open fillet joint.
kazlx
Tustin, CA
This is also the way I do it. Makes for a nice, rounded outside corner. All my hardware filing cabinet dollies are done this way.
Yes. If you need a sharp corner you need to adjust a little. But this works very well for blending. A little work with a flap and it looks great. I also bevel the top and bottom so the weld has some room to lay down, usually 14g or thicker. The thinner stuff there's usually no room, you're better off with a tight 45 all the way around.
