Noltz
I'm plotting a 240v run to my attached garage from my main panel. Well, 2 runs actually; A 240 for a future lathe / mill (30A?), and a 40A line for a Generator in-feed with an interlock.
In the garage the electrical is surface mounted in NMT. I have two 1" holes drilled through the foundation for the NMT passing into the basement. My question is how do I properly switch from the 15' length of 8/3 Romex into NMT (which must be loose wires)? With the 120v run I just used a utility box and a NMT adapter in the basement. Is it the same requirements for 240 with 6 or 8 gauge?
