On rebar would be in standard slab. I m not going post tension.Only homes that I know of around here with PT slabs are tract homes. Because its cheap and easy.
I would not do one unless the conditions actually warranted it and it would not just be "post" tension.
They would have to "pre" tension it first for me to except it. Basically the cables need to be as flat as possible.
Yeah good luck on that as the 2x forms they use won't allow that .
The way they lay the sleeved cables in looks like a roller coaster ride. Then when its post tensioned it does not provide an evenly distributed tension. Some parts will be pushing downward, some upward.
Control joints?
Never saw a need for them really. Ive seen concrete cracks than run directly parallel to them. Inches away while the joint is still intact.
Eta.
He is going to do rebar also in a post tension slab?
Hmm.
Is that a good idea? IDK.
Seems it would make the concrete pull away from adhering to the rebar when the slab is compressed.
Ah. Misread your last post.On rebar would be in standard slab. I m not going post tension.
Really strong magnets!How the hell do you pre-tension a slab?
Not the slab. The cables.How the hell do you pre-tension a slab?
You no nothing about post tensioned concrete. All PT cables have and need profiles (up & down).Not the slab. The cables.
When they lay those cables in and attach the ends to the forms they are loose and sloppy.
Up and down, left and right.
Concrete is poured and now those cables are set in concrete.
When they are tensioned you have forces going up , down, left and right.
As you know from your response, the answer is 'you don't'. That post was full of inaccurate statements. Just to clarify for those who might be interested (all three of you)How the hell do you pre-tension a slab?
Cast in place concrete is post tensioned. Steel tendons that are sleeved in plastic to prevent bonding with the concrete are run through the slab and out through the formwork. After the concrete has adequately set, a jack is placed on one end of the cable and tension is applied. The tendon is secured at each end with a steel block to maintain the tension. Tendons are generally run flat in relatively thin slabs on grade but in structural slabs and beams, the tendons are run where tension occurs i.e. higher over supports and lower over spans.
The potential downside to post tensioning is that if a cable is cut or the restraining blocks fails, the tendon can shoot out of the slab with tremendous force.
Precast concrete manufactured in a plant is pre-stressed. Since the steel forms used in a precast plant are much stronger than job built forms, tension can be applied to an un-sleeved cable prior to placement. The concrete bonds to the tendon over its entire length so no anchors are needed at the ends. The cables are just cut off flush with the concrete surface.
Unlike rebar, which is passive and doesn't come under load until the concrete has cracked, post tensioned and pre-stressed tendons apply an inward force to the concrete, preventing cracks and increasing load bearing. My apologies to the engineers who are probably cringing at my simplistic explanation.
Looks nice and straight, flat.Pic of our house slab
You answered your own question. How tendons are profiled, depends on whether the slab is supported on its edges, or is floating, or other.Rusted nut why would you want ups and downs in the tendons for a flat residential slab ?
I understand in some cases you may desire to have a low placed tendon toward the middle so when its tensioned it will provide lift to the center of the slab.
