I am thinking of putting an angle iron against a safe like in my picture, safe is bolted down although it is sitting on plywood.
not a 100% but the idea is make it less easy for jamming a pry bar or at least slow things down. (I know, if they want it... given enough time.. etc etc)
1) do you see anyway this actually compromises the security?
2) how can I make the screws or lag bolts more secure. Maybe cover it up with epoxy so you can no longer fit a socket over. if bolts located less than the stroke length of a sawzall may make it hard to use. But sawzall could get under unless I epoxy the bottom of the iron as well.
Thanks I know there is a lot of security experience on here.
most beople call me to see if I can open it they lost the combo
