600SL
Hello
I am installing a heat pump in my garage and I could use some suggestions on protecting the refrigerant lines. I have a steel building with steel interior walls. Removing the steel interior wall panels to get behind them is not a reasonable option at this point. The lines have to come down a 10' wall where they will be exposed in the shop environment.
I'm considering putting the liquid and suction lines in to separate PVC pipes for protection a 2" PVC for the 1 1/8" insulated suction line and a 3/4" CPVC for the liquid line. The suction line will be 1 7/8" diameter with the insulation. Not sure if I can straighten the coil enough to feed it into the 2" PVC.
Anyone try this or have alternate ideas. You can see my link below for pictures of the interior.
