Proto Crowfoot thingy Set Use?
Zewnten
What is this used for? I was thinking of buying it for pain in the *** hydraulic fittings but don't know if it would be sturdy enough.
Tubing / Tubing Appliance Co., 7112 S. Victoria, 10321 Anza Ave., Los Angeles, CA / "TAC" ratcheting tubing wrench / acquired by Proto / patent 2578686 & 2578687 Dec 18 1951 Herbert L. Fish & 2691315 Oct 12 1954 Allen J. Brame / http://alloy-artifacts.org/proto-empire.html#tubing-also-tac / /
The company and patent rights were acquired by PROTO
Proto / Proto Industrial Tools, New Britain, CT / https://www.protoindustrial.com/en/Pages/Default.aspx / http://alloy-artifacts.org/proto-empire.html / https://www.garagejournal.com/forum/threads/proto-tools-picture-thread-post-yours.416549/ /
The tools in that box were intended for use on aircraft. I'm sure they'll do just fine. ;)
Smokeshow69
You are correct, they are for hydraulic fittings. You don’t use these to break the fittings loose necessarily if they require high torque. But they are life savers in some really tight areas. How much was this set? I am in the process of cleaning this one up and this is a 1-13/16.
Ricky Joe
Roanoke, Va.
I would be interested to know how much the set is, also. There was recently one on eBay for $2800. I don’t know if it sold, but I had a small set with the Proto Flying Lady box that I sold for $100.
Smokeshow69
Interesting…I am not sure if any manufacturer is making these now. They are very high quality and if they are not currently being manufactured, I could see why they commanded a high price
Iridium rand
Wow someone else with these ratcheting ones! I have a few from the old tool box at work, seems like a great concept for difficult hydraulic fittings but I don’t work on them enough to have used it yet, and apparently they never caught on so could be a great idea that was just slept on and never made it or maybe they just aren’t that useful.
Only problem i can see is that there’s obviously only one position on the ring where you can get it on or off the fastener, it’s a full closed circle once you ratchet at all so you could possibly end up in a difficult area and have a tough time getting the tool off of the fastener
robert6715
Alaska
The ones in the OP's pic are 8 sided. What has 8 sided hydraulic hoses/pipes? Just curious, been working on equipment for years & dont recall running into any 8 sided hydro fittings.
