Tool Pants
Here is my expenience with a Williams ratchet adapter.
http://www.garagejournal.com/forum/showthread.php?t=27220&showall=1
So I bought a Proto 5447 that has Los Angeles on it. As far as I can determine this is an older version. To change direction you slide a wing. The newer version is also 5447 but you turn a knurled ring to change direction, like my junk Williams.
This Proto is the older wing version.
How do I take it apart? Unlike the Williams the Proto has no clips that I can see. There are 2 holes in the body. In the second picture I put a pick in each hole so you can see where they are.
Just cranking this thing around it sounds like there are 2 pawls inside. I wonder if I put the selector in the middle/neutral and shove something into the holes to depress the pawls, and then pull up on the drive end. I would have tried it already but my third hand Thing is not around today.
