Hello, maybe someone can advice on which tool would be better for:
1) cutting a 10mm rusted nut without damaging everything around it;
2) making small cuts in sheet steel up to 1 mm.
I was thinking about:
Proxxon IBS/E
Do you know if it can cut or grind steel plates of this thickness?
Metabo GE 950 G Plus
May be this would be more versatile tool overall, with low RPM setting it can also be used with metal brushes. But I am not sure about the cutting disc diameter, I wonder if there is an adapter for smaller cutting discs with thinner shaft (like for dremel tools)?
Or maybe these tasks require 2 different tools, what do you guys think?
Proxxon IBS/E
