pry bar holder
hoston23
godley, texas
i need a pry bar holder for larger bars. i was going to order the one from Sunex except all the holes are small and wont hold my large bars. i have about 20ish bars.
LB-1911
Northwestern Il.
I'm sure Ign won't mind if you borrow this design..
For about 8 years I've been meaning to do this instead of having my pry bars in a heap on the bottom level of my cart.
Last night I got a wild hair and grabbed some scrap 20ga. Bent it up in my finger brake and did 1" holes, dimpled. It's not perfect but soooo much better.
Rockett69
Austin, Texas
Simple and effective... thats a great idea, kudos to Ign. However, I have all the tools to do that.... I don't want to do it unless I have to buy a new tool!! :lol_hitti
jakemac
New England
How did IGN 'dimple' the holes?
Dimple die and a press?
OR .....
Drill a hole in a 2x4 a little larger than the hole in the metal. Center the metal hole over your wood hole. Place the ball end of a ballpein on top, and whack it with a deadblow hammer. Don't use a metal hammer, you could damage one or both hammers, causing a piece of shrapnel to fly off.
gdocktor3
Connecticut
Type "Homemade screwdriver holder" into google images. There are a million different ideas. Just make the holes bigger. I have a pry bar box similar to sunex, but forget the brand. It's older. A few of my bars were too big and I had to bore the holes out a bit. To be honest, I could live without it because it takes up a lot of room when opened, but it's there now.
