PT Deck - Stain? Seal? Leave alone?
glennm
We have a deck that is 22 years old. After that amount of time and pressure washing it annually it didn’t look too good anymore. Last weekend my son and I removed the decking and it looked good on the underside so we just flipped the boards and screwed them back down I ran a surface cleaner over it and it looks surprisingly good. Now I am thinking about sealing it or using a light semi transparent stain. Everyone seems to have a different opinion - what do you think?
CombatNinja
I prefer toner. It is easy to work with, no prep is needed to redcoat other than a cleaning and maybe a hasty scuff sanding to raise the grain. Oil based toner will soak into the wood and simply slow down the rate at which the wood can take on and give up water, which is what you are after.
K'ledgeBldr
Johns Creek, GA
22yrs where!?
You’re clearly getting the most out of those boards! I’ll assume they are 2X- I very seriously doubt 5/4 would last that long.
Anyway, as far as a stain/sealer, I guess it would boil down to cost in relation to how much longer those boards would last. In other words, I wouldn’t waste the money on stain/sealer if the boards only have a year or two left in them.
I’ve been a big supporter of TWP for decks and fences.
jack stand
Lakes Region Maine
Maybe you happened into a great ”run” of wood and the treatment 22years ago and miraculously get another 10 out of the reverse side. But like k ledge said above, I'm not sure it's worth the additional investment of a sealer or stain.
Lot's of sun can degrade wood and if your climate doesn't include much moisture I'd think your chances are much better and some type of "moisturizer" treatment (oil) might just be well worth it.
u2slow
BC
A gently pressure wash each season, and re-treat with the the green PT juice every 2-3 years. I refuse to put on any coating that can lift and peel/flake off, because it will.
My Old Tools
Hamrick Lake, TX
I used Armstrong Clark semi-transparent oil based stain on my 20 year old PT deck. Stripped it first with lye, then treated with OA, then rinsed clean and allowed to dry. It has held up well. This spring instead of pressure washing, I used my floor buffer with a stiff bristle brush. Sprayed with bleach, oxy, and water first. MUCH faster and easier than pressure washing.
gba2331
I’ve been doing this with my Ipe deck for years, it’s much gentler on the boards than powerwashing.
78SC4X4
Port Orchard Wa
My PT deck is 26 yo and I'm in the Pacific Northwest! All I've ever done is power wash and treat with Flood CWF-UV penetrating wood finish.
G
glennm
22yrs where!?
They are 5/4 deck boards and they actually look brand new after being flipped
CraigStu
Blacksburg, Va
My brother's father in law did similar. Well, he had similar done. A clear sealer first. Next spring pressure wash and clear sealer. He said the key was not going crazy w/ the pressure washer. A few dirt spots he used bleach or a deck board cleaner. The nice thing was he bought whatever clear sealer they had on sale each spring. It was only going to need to last a year so high quality wasn't needed.
thammel
Maryland
I used sikkens Cetol SRD in the past. Never got much life out of Thompson's. Sikkens might be hard to get now due to VOC regulations
danfromsyr
Cicero, NY
my deck boards are ~25yr old PT and are structurally just fine..
have a nice grey barn patina from aging
I don't do anything to them.. no stain no wash no pressure wash..
not all splintery. and this is in a 4 season exposure climate.
I intend to reuse and flip them when I build my new rear deck so I can put a different entry on the front of the house.
toolmiser
La Crosse, WI
My deck is probably 25 years old. Pressure treated. I apply a semi transparent oil base stain every couple years. I made the mistake of using solid once and I had to strip it. Ours looks pretty solid.
