Puget Dude’s creations and fabrications (Random project thread.)
Bears Fan
Indiana
20260413_113525-jpg.2521956
It's a beaut Clark and all the little lights are twinkling :cool:
P
PugetDude
Superstition Mountains, AZ
Started tearing apart the big built-in bench to move it to the new shop.
It's (4) 46" Husky tool cabinets, i installed them on a tapred base to level them up on my sloped garage floor.
Apparently I had an uninvited guest slither in behind it at some point. Probably after mice, but he left his calling card...looks like about 4ft long and 10 rattles- probably the same snake I killed last fall after it struck at my neighbor when she was exiting our garage one night-luckily my wife heard the rattle and yanked her back just in time- she came right out of her shoes!20260414_175912.jpgMore to come.
Jgaz
A shovel works best, and then you’ve got the perfect tool to finish the job. One of my favorite songs growing up was “Spiders and Snakes”!
When I first saw him he was coiled below where I keep my shovels and snake grabber.
He had no intention of letting me near the tools.
I was controlling the dog and getting him into the house when it made a break for the bushes.
P
PugetDude
Spent some time today moving the 4 big tool chests over to the new shop. Moved them full, they probably weigh 400# (or more) each.
Since I was working by myself I decided that I might try something besides brute force and ignorance this time around to get them moved. (This was the third time I have moved them...)
My little 1.5 ton floor jack, a few assorted pry bars, composite shims and a fiberglass HF moving dolly turned this into a manageable one -man job.
I was lucky in that the floor pitch in the new shop turned out to be exactly the same as the existing garage. I dragged the base plinth out into the driveway, stripped off the plywood top, flipped it end for end (slope is now R-L instead of L-R) and re-installed it in the new shop.
Nice and level without any adjustments necessary... ( don't panic- that sloppy **** joint gets covered later...)20260415_151442.jpg
Took a bit of finagling to get the base cabinets in place and butted tightly together. 20260415_162904.jpg
They were still heavy, especially after I got them wrestled off the dolly and started up onto the base. Final inch or so of positioning was done with a 2X block of wood and a big Garland rawhide mallet.🤨
I'll get them leveled front to back with composite shims tomorrow, then start working on the galvanized diamond plate pegboard that goes above them so I can start moving everything else over. 20260415_170720.jpg
I installed them in a slightly different order this time to put the most used drawers closer to the center, it will probably drive me crazy for a while until I get used to the new layout.
More to come.
dscheidt
My trusty old Red Ryder BB gun works well, too and at a safer range than a shovel...
One summer I was visiting my grandparents, and was fishing at the pond down the hill from their house with my cousins. We heard a car come up the gravel drive to the house, a scream, and five gunshots. There wasn't more screaming, so we went up to see what was happening, and found out the preacher had arrived for Sunday dinner at about the same time as someone had discovered a snake under the porch, and my grandfather had tried to shoot it -- with a pistol, because he'd yelled 'bring my gun', and got brought that instead of a shotgun.
At dinner, the preacher said "I must say Mr --, I was expecting a more welcoming reception than you brandishing a revolver at my arrival."
dscheidt
My little 1.5 ton floor jack, a few assorted pry bars, ⁶composite shims and a fiberglass HF moving dolly turned this into a manageable one -man job.
I'll get them leveled front to back with composite shims tomorrow, then start working on the galvanized diamond plate pegboard that gies above them so I can start moving everything else over. 20260415_170720.jpg
I installed them in a slightly different order this tome to put the most used drawers closer to the center, it will probably drive me crazy for a while until I get used to the new layout.
More to come.
If your do it again, pipe rollers and air bag shims are amazingly capable, if used with a little creativity and some blocking.
P
PugetDude
Well, I decided I didn't like the asymmetrical layout with both of the tall New Age cabinets on one end, so I pulled it apart, shoved one of the cabinets to the opposite end, moved the base and then put the four tool cabinets back in place. I moved all the galvanized diamond plate pegboard over from the old garage. Tool layout is getting revised a bit this time around20260418_152818.jpg
More to come.
P
PugetDude
Making progress...20260419_160414.jpgStill need to get the TEXACO letters installed up above the facade roof. Need the high lift garage door tracks raised to do it, but apparently this simple task has completely stymied Wayne Dalton, they have been promising to come back and correct it for 8 weeks... it's now officially taken them longer to build and install two doors than it did to build the entire garage from foundation to finished paint!
Door #1 was installed 21"from the ceiling. Door #2 is less than an inch from the ceiling. WTF W-D?
Old Man Roger
Palm Coast Florida
Got any suggestions?
You could get some ideas from RedLeaders 1950s Craftsman Garage too.
P
PugetDude
I second Red Leader's garage. He did some very cool things!
I was following his thread years ago, but now it looks most of the photos were corrupted by the host sites...and Red Leader hasn't posted any updates in several years. He did do some really cool stuff. Maybe someone can lure him back here?
  • Like
Reactions: 555
Old Man Roger
Palm Coast Florida
I just looked at his thread yesterday and the pics worked? They did take a second or two to load.
  • Like
Reactions: 555
P
PugetDude
Loading up the old gym lockers, not going to use them in the new space. They're going to a friend's shop in Chandler. They're a lot heavier than I remember from when I bought them 6 years ago.
After a couple of false starts, I finally decided there was no way I was going to load the bank of 4 lockers by myself, so I used the rolling shop crane I built a couple of years ago. Took longer to rig the pick than it did to load.20260425_104208.jpg20260425_104643.jpgMore to come.
larry4406
Northern Virginia
I like that crane!
I need to go find the details on its build. Is it in this thread?
