Puget Dude’s creations and fabrications (Random project thread.)
Bigblue&Goldie
Half the people that live in my subdivision own two screwdrivers but only know how to use one of them. Any time they come into my shop it's like the scene with the monkey touching the monolith in the Stanley Kubrick movie 2001. 🤣
More worried about someone driving in the gate and seeing it as a target of opportunity.
When you have a Butler, you don't need to concern yourself with screwdrivers......
P
PugetDude
Superstition Mountains, AZ
Our community landscaper came through big time on the bench installation. He put in an oversized paver pad, a walkway, a flagstone bridge over the drainage and landscape lights. IMG_20260717_124923 (2)~2.jpgIMG_20260717_184403.jpgWay more than I expected, but a fitting tribute to a good friend and neighbor. We got it done just in time for the one year anniversary of his passing.
Very unsual rainy day for pictures in the Sonoran Desert, Apache Junction had major flooding in the desert washes, with low-lying roads under water.
More to come.
larry4406
Northern Virginia
More to come.
Well done!
The zeroscape/xeriscape whatever is called looks very nice.
P
PugetDude
Somehow ended up with a day that wasn't already booked up, so I knocked out a quick welding project. Pulled 30' of 1-1/4" square tube out of the steel rack and built a base for the big walnut slab sofa table I am building for a neighbor.
Her slab is the one on the right side, imeaures approximately. 16" x 75" x 2" thick. The live edge slab is going to be my office desk if I ever get a chance to work on my own stuff...🙄
Here is the photo she sent me for reference: Screenshot_20260513_142717_Amazon Shopping.jpg
And, here's the welded base ready for final sanding. I used 60 grit with the random orbit sander to remove the grinding marks left from the flap disc I used to flush grind all the welds
Welded 3/16" x 1" mounting tabs for the slab on the top, 3/8 threaded inserts on the bottom for leveling feet, and got it dropped it off at the powdercoater for sandblasting and satin black this afternoon.
More to come.
P
PugetDude
Bosch 10" jobsite tablesaw ...
Ripping some handselected construction grade 2x6 White Fir boards.
This little saw continues to amaze me. Same $15 Dewalt rip blade has been on the saw for over a year. It's cut like this out of the box, I have never had to adjust the fence. These strips were about 60" long. 20260807_164400.jpg
I'm not doing @jar944 level cabinetry...
I have been working on handrails and posts to replace 20 year interior log railings in the loft at our summer place.
Pictures to follow...Getting close to getting them finished up.
P
PugetDude
My bride wanted to change the interior loft railings from "Mountain Rustic" to "Mountain Industrial "
The ~7" diameter log posts were well- anchored and the previous owner had all new flooring installed around them, so I elected to leave them in place and work around them. 20260714_105825.jpg
After looking at a few options, I decided to wrap them with 1x pine. I found 1" x 16" x6' laminated & sanded pine panels at Lowes, figured they would be a lot more dimensionally stable than than 1 x 10 comon pine boards. Price was about the same as dimensional lumber.
Built simple 8-1/4" square ⁷boxes with ****-joined corners since the joints are going to be covered anyway...20260714_105856.jpg Two of the post covers had to be sculpted to cover the logs on the inside and outside corners.20260717_173601.jpg
Two others were 3-sided boxes for the half logs on the end walls. 20260717_173604.jpg
We wanted to complement the knotty pine ceilings and Douglas Fir glulams, so I sorted through every unit of whitewood studs at HD, Lowes, and the local lumberyard for the clearest, straightest and most vertical grain whitewood studs I could find to resaw into stock I could use. (Turd polishing at it's finest, necessary because there are no specialty lumber supply houses within 150 miles...part of the charm of mountain living.)
More to come...
P
PugetDude
"Mountain Industrial" is apparently a thing. I wasn't aware of it until my bride exploited my ignorance by sending me examples and ideas...
Natural wood, metal accents, welded wire... right down my alley. Throw in the ability to add some diamond plate accents and I was all in. 🤣
I had picked up a bundle of 1 x 1 x1/16" aluminum angle at an estate sale a while back; this finally seemed like a good project on which to use it. Primed and painted it satin black and wrapped the corners of the posts with it; secured them with #4 black truss head screws. The top caps are black diamond plate with a 1-1/2" angle cap frame.
I had a couple of Wild Hog track kits left over from the outdoor railings I installed last summer, but apparently HD and Lowes have dropped the Wild Hog product line and replaced it with a similar system by Trex. The wire panels appear to be identical, but the tracks are different. I was able to make them work together. 20260804_185751.jpg
Still have the finished top rails to install. I cut and planed them to size, My wife is handling the staining and finishing.
The railing section that butts up to the fireplace was a bit of a challenge. Took longer than the rest of the sections combined, but I am happy with the way it turned out. I used 5" Tapcon screws to secure the frame to the fireplace. It's really solid. (Paging @Dan in Pasadena ....🤣) IMG_20260807_190758.jpg
Still have way to go on this project, but at least the loft is fall-proof again. Hope to get the rest of the trim finished up before our next houseguests arrive next week...
More to come.
readhead
Durango, Co.
Yes, mountain industrial has been all the rage here in Durango for several years. However recently I saw an installation in a house that we were doing the rails for that really caught my eye. The decorator brought in a painter that weathered the black bits by dry brushing with various rust tones to soften the black and it was very effective. I wish I had taken some pictures.
Of course your work is very well done Scott but I am a little disappointed that you didn’t work in some rebar.
P
PugetDude
but where is the rebar?
Ya-ya, that looks good scott but where’s the rebar?
You’re slacking bud. 🥹
