scootermcrad
Hey guys!
Well, I've decided that my somewhat under-powered garage really needs to have a new cable pulled to its 120 AMP sub-panel. The garage is attached to the house via a breezeway with an attic space. Current wire passes through this, but is not run very well.
It was suggested by a very reliable source that I should run 2 AWG THHN type wire. Big stuff, but should be just right for the amperage load the garage will see. (lathe, mill, welders, compressor, few lights, and a fridge). The wire will be pulled through the crawl space, up through the wall of the house and into the attic of the breeze way, and down into the panel in the garage. The walls that the wire will be pulled through are completely open right now for a renovation, so this is a great time to pull it.
Questions:
* Should I run a 3 conductor or 4 conductor?
* What TYPE of breaker is the thing to buy these days?
* Are there similar wire types to 2 AWG THHN worth considering?
* what would one expect to pay per foot for this type of wiring? (need around 140 feet, I think)
* Do I need to run conduit under the house in the crawl space, or just string it and support from the floor joists? How about the walls? Just run it like any other kind of wire through the walls?
Questions:
