Puma Compressors witch one is better
cj58
I'm trying to decide between two compressor to restore a car, sanding and painting, Puma seems to have compressors with good reviews at good prices.
The two I'm looking at are the 5HP 60 gallon single stage, PK6560V http://www.aircompressorsdirect.com/Puma-PK6560V-Air-Compressor/p592.html and 5HP 40 gallon two stage, TE-5040V http://www.aircompressorsdirect.com/Images/Puma-TE-5040V-Air-Compressor/i13941.html. Would the two stage with the 40 gallon tank keep up the same as the single stage 60 gallon tank.
AP514
Pearland, Tx
could not find any real good info on either of them.........the 60 gal have more CFM at 90..so if your going to be painting/sanding alot the higher CFM would be best ?
shoot summ
This thread had some good info in it... :)
http://www.garagejournal.com/forum/showthread.php?t=260882
As stated, if you look at the specs tab the 60 gallon has more CFM.
Like I answered in your other thread I linked, it depends what you are doing. Running short burst air tools or low CFM tools, it won't matter. Fire up something that likes air like a sand blaster, blast cabinet, or many sanders, and it will make a huge difference.
