Pump for a sink
LOW1
ontario
In the process of building a combination small shop and boathouse at our cabin in northwest Ontario. I have an old farm sink that I would like to use for a fish cleaning sink. I can't hook it to the plumbing system but it will be right over the lake and I would like to pull water from the lake for the sink. Any ideas of what sort of pump I could use for this? We have regular electricity or "hydro" as its called up north
ez-duzit
Marina del Rey
Use a manual pump similar to what is used at the galley sink in small boats.
Marctrees
TX/LA border - Toledo Bend
Seems to me to use KISS thinking and look for manual hand pump.
Only thing is, would be nice to have both hands available to rub down fish while rinsing.
Don't forget to consider winterizing complications.
Marc
Marctrees
I suppose if you have power at this boathouse anyway,
You could find an appropriate small 120vac to 12vdc converter...
and get https://www.google.com/search?ei=Kr........0i71j35i304i39j0i13j0i20i263.GEbs6Uxex58
Shur flo and flojet are the most common, have been in use in virtually all RV's for yearssss.
Only thing is for winter you would have to pull and bring in the pump...
Or design plumbing, pickup line made of flexible hose ? to be able to dip the intake tube into a jug of RV antifreeze.
Marc
Marctrees
Whatever you get, make sure it can self prime the vertical lift distance you will need.
And obviously, a good strainer at intake..
Maybe DIY using stainless chore boy dishwashing pads.
Actually, Cu may be better at keeping down any algea growth.
Marc
Marctrees
I see cgt80's link uses 120v, no need to convert to 12vdc.
Amazon page shows - "self-priming up to 9 vertical lift feet"
But, always doublecheck anything on retailer webpages.
Marc
L
LOW1
ontario
Thank you all for your replies. Yes, the entire boathouse is GFI protected. I will probably go with the 120 volt rv style pump since two hands will be needed two clean the fish which would make a manual pump awkward. I'll probable go with a copper pipe with a filter on the bottom to go in the lake and a length of connector between the top of the pipe and the pump so that I can pump it full of antifreeze in the fall.
It would be nice to have a fully submerged pump that could stay all winter under the four feet of ice but I don't want to have to deal with a pressure tank. Thanks again.
