Looking at sump pumps...found 2 pumps... both 1/2 HP, but one nametag said 13 amps and the other said 6.5 amps. Both 110v units. Is it possible to have 2 pumps, both with the same HP rating, so different in amperage?
This 3/4 HP* corrosion-resistant automatic submersible sump pump comes with a heavy-duty, energy efficient motor only 7.5 amps, a built-in check valve and 8 ft. power cord
*As rated by engine manufacturer
There are a lot of "funny" HP ratings used on consumer products.
In the case of the 1/2HP pumps you mentioned in post #1 it is highly likely there is some misprint caused by translations from Chinese and metric units.
Check out this pump:
http://www.grainger.com/Grainger/items/3XU84?Pid=search
Item number 3XU84
The pedestal pumps are more $$$ but they last a long time.
-And it takes continuous HP to compress air. That peak HP can help the compressor get past that last little "hump" as the tank is building pressure but otherwise it is meaningless.They get by with that rating most likely by rating the peak hp rating. Not the running hp rating....... Kind of like most 60gl air compressors, they say 5hp motor, but that's peak hp rating, they are really 3hp while running.
