Purchased a No-Mar tire changer
sleepy127
Flaherty, KY
I paid $300 for it, hopefully I will be able to make my money back by using it. It is an older Professional model.
DieselSaves
Big Sky Country
Those work well for tubeless tires. I had the lighter version of their stand with the same accessory kit. I changed car tires and that worked alright, I couldn't get the beads broken on older ATC tires with it, and old spoked tube type MC tires were much easier to do with simple spoons on a piece of plywood. It did work well on tubeless MC tires that hadn't been mounted for too many decades.
tatra
pirate contest city
Never used one of those. Have to look up some youtube on use.
As for tire lubes, dismount I just use soap and water unless freezing out. Then I use low temp WW fluid. For mounting I prefer Freylube No Rim Rust. I have used Murphys and didn't care for it. Buy a small tub of each and try them both out. Murphys I find to be stringy and gets every where. Freylube is a grease. Works excellent on rust belt problems. Truth be told, haven't used Murphys in over 20 years tho.
