HoosierBuddy
I hadn’t really thought through how I was going to drill 15 inches through this hard maple lamp base piece and end up centered at both ends until I was well into my project. Ended up center punching both ends, drilling a 1/8 pilot hole 2” deep on each end to give the spade bit something to follow, then I dropped my table and jacked up my head and drilled the top about 8” deep with a 3/8 spade bit, moving the head down once as the 1150 only has 6" of quill travel. Then, I flipped the piece end-for-end in the vise and drilled the other way with my fingers crossed.
Worked like a charm! I’m probably more lucky than good on this hole.
Phil
Phil
