Put down poly when it's raining?
streetdaddy
Nashville,TN
I got the day off and my floor prep is done .It's raining outside. Can I still put down the polyurethane? Or should I wait?
malibu101
Walnutport PA
Is the humidity now (and until cured) within the manufacturers specs?
I don't not know nothing about coatings- But I think I'd wait.
LegacyIndustrial
deerfield, IL
The reason you don't want to install coatings in the rain:
A fine accumulation of moisture can occur. So slight you may not realize it's there. This moisture can act like a bond breaker, causing failure. Wait it out.
Armorpoxy
Wait. A lot of moisture could cause issues with curing and or adhesion.
Jazz1
Thunder Bay On.
what he says...same reason I don't wet my floor before painting a vehicle.
