Mamrak76
I have researched the principles of a geothermal heat pump. I have a standard heat pump (air source) with an outdoor unit. Would it be possible to put the outdoor unit in a chamber underground where the temp is always 50 degrees and extend the copper lines and add extra refrigerant. I think it would always operate at peak efficiency regardless of the outdoor temperature? I know there would be issues with digging a deep enough hole and having access, not to mention replacement. Ambient temperature is why they don’t use air heat pumps in the north. This would eliminate this issue. But any suggestions as to why this wouldn’t work?
