curtis9
This spring (if it ever quits snowing here) I am going to put up a 30x40x14 with a attatched 12x40 lean to on one side. This is a pole barn style building with a metal roof and metal siding. Eventually I will pour a slab with pex in it to heat the 30x40 part. My question is what is the best way to go about the roof? The building supply company said to use foil bubble wrap or insulation board under the metal. Another person said that i could just use some felt paper under the metal since i will be putting in a ceiling and blowing it in with cellulose insulation. This will be in northern michigan where its cold really cold in the winter and hot in the summer.
