PVC DWV pipe sound insulation
strutaeng
Dallas, TX
Hi, I'm working on an addition project and have an upstairs restroom. Below is a bedroom. I was considering installing cast iron DWV, but everything was done is easy-to-work with PVC Schedule 40...Forgot about how noisy PVC drain pipes are until now, LOL.
Found Buna-N pipe insulation for larger pipe at McMaster-Carr. https://www.mcmaster.com/pipe-insulation
Anybody insulate drain pipes to mitigate sound?
I have 5/8" drywall throughout, so that will help somewhat. Floor is also getting insulated with R-19 fiberglass for comfort. Maybe get a bag of Roxul for floor bays with the drain pipes?
Todd.Brock
Cincinnati
My buddy built a new house. We insulated every interior wall with rock wall sound control and wrapped all the pvc pipes with MLV - Mass Loaded Vinyl. Can’t hear water moving through pipes , so I assume it did the job.
He bought a 50 ft roll. We 8 ft long cut strips to what ever width for the diameter pipe, and zip stripped it all on there.
kbs2244
In Lake Forest, IL. I think that when they finialy allowed PVC they required lead tape along any straight over 12 inches.
The tape was apx 1/4 thick x 1 inch wide.
Self stick
We got it at the local plumbing supply house.
The idea was it stopped the vibrations.
Bruce 993 SEA
La Conner, WA
I had the exact situation so I went searching on the interwebs...
Found a forum for home theater systems that had a thread about a bath above the area where the guy was building the home theater. He wrapped the ABS/PVC (PVC being quieter than ABS) with carpet padding.
So I dd that and wrapped them twice and sealed it all up with duct tape. Then the entire ceiling was packed with the rock wool sound insulation. You cannot hear the toilets flush now. Before, you could hear the cat walk across the hardwood floors above.
Cast iron is the best and if it were a new build, a cast iron stack would be great.
The MLV is prolly better that the carpet pad but I had just pulled the carpet out of that room.
Let us know how it goes...!
Norcal
If someone is concerned about noise from upstairs DWV piping, cast iron is the best way any other way is a band aid.
NUTTSGT
Northern Central Ohio
If I had an issue and used what I have at hand, it would be some Reflectix bubble wrap. I've wrapped a bunch of my older duct work in the basement with it and while working down there, it seems quieter.
A couple of wraps with that and fiberglass batts in the wall cavity.
