PVC Pipe Ends
D45
NW INDIANA
For my curiosity, who "straight" cuts and then glues pvc and who cuts then "chamfers" or bevels the edges, before gluing?
mike93lx
Richmond, VA
Depends on the size and circumstances. Sometimes I just clean off the shavings, sometimes it's a bigger bevel. If I need it to go together easily or it's a particularly important situation, then it gets more effort.
D
D45
NW INDIANA
1-1/2"
I'm thinking about ditching the corrugated hoses on my above ground pool, and looking at flexible pvc vs rigid pvc
larry4406
Northern Virginia
I use a chop saw for nice square cuts.
Then I use a razor knife to score and deburr the ID and OD.
Primer then glue.
It’s just what I do. 🤷‍♂️
PCustoms
VT
If new plumbing around the house I usually use a chop saw, sometimes a recip saw.
Old plumbing gets whatever tool fits the spot.
Usually use this to deburr
Copymutt
Colorado
Good practice to chamfer, eliminates debris that might work loose after flushing, and plug orfices.
Crazyjake8493
Upstate NY
I've never chamfered a PVC pipe in my life, but I typically only work with 4" and under. Not sure if there's benefits for chamfering larger sizes.
I just cut, deburr, prime, and glue.
rharman
SoCal
Like @PCustoms, I use a deburring tool on the inside and run a piece of sandpaper over the outside. Just to clean off the swarf.
housewolf
East Texas
I’ve probably gone through a couple thousand gallons of glue & a fair bit of primer as well. Up to 6” we just remove the burr by hand. Over 6”, put a bevel on it with the side of the chop saw blade. Every PVC leak I’ve ever “autopsied” wasn’t cut square or pushed in all the way.
  • Like
Reactions: D45
mm08822
I started beveling the inside of pvc conduit after having snakes hang up on the square cut ends in the factory belled ends. Works very well.
Also found it helpful to bevel the outside to enable faster assembly and ability to rotate for alignment. Nothing worse than the glue setting while you squirm for proper alignment.
PCustoms
VT
I've done that as well but it's not as smooth operating as it is on the inside. Kind of herky-jerky.
It's a different motion, hold the tool 90° to the pipe and put your thumb along the outside of the pipe. Pull the tool towards your thumb as you rotate the pipe.
acer66
Western North Carolina
Like others no proper chamfer I just deburr the inside so nothing can get caught there.
Outside gets deburred so it does not create a void in the glue even I also twist it.
Does not take long and fixing it is to time consuming.
Might look into a debrurring tool though since I am doing more plumbing lately.
rharman
SoCal
Tried that and other variations. Just easier to put a piece of sandpaper in the palm of my hand, plop the PVC into it, and twist the PVC back and forth a couple of times.
PCustoms
VT
I might have used my disc sander once or twice...
