I need to run some PVC pipe to allow for my shop vac to be in another room while I have two feeds going to my work bench. My main question is what size of tubing is best suited for a typical Sears type 2HP 20Gal 120v shop vac. The run I
have to make from the vac is:
Up 8'
Across 20'
Across 90 degrees again 10'.
From this last 10' of pipe I have to go down twice 8' to my work bench; thinking once at 4' and again at 10'.
So the total pipe would be 46'. I'd have the second downpipe closed of course.
I am mainly using this for suction of dust and Copier\Printer Toner so the need to **** up marbles isn't there
There will be times when both downpipe will be needed for suction.
Thought's
Up 8'
Across 20'
Thought's
but I hate the sound of a vacuum, I'd rather listen to a table saw
, and see if my Vac ***** enough; if not I can always spend more money on one that ***** even more.
