PVC plumbing pipe for low voltage
gumbudah
Northern Wisconsin
So i've got some unused 2" pvc plumbing fittings. I want to put a conduit in my walls for future pulls of cable/ethernet/24vdc security wires. They fit fine on 2" electrical ent and they fit much better in the tight quarters I'm trying to do this in. Does anyone know of any code reasony why these fittings couldn't be used? there will be NO 110v or higher ac wiring going in these things.
njride
the 90 degree plumbing fitting will be impossible to get a snake and pull wire through. Wire doesn't flow like water.
nehog
Jaffrey, NH
For low voltage wires, you can do whatever you want...
As to flammable... So is wood.
As to fumes... Burning wood gives off noxious fumes.
As to inspections... NEC lets you have a lot of leeway with low voltage circuits, including no conduit at all.
As to 90 degree bends... OK, that will not work well!
G
gumbudah
Northern Wisconsin
As to the burning part, I have pvc already in the walls for other plumbing, I don't see much difference.
As for the elbows, the wires I'm going to be pulling are ethernet cables.... those will pull around a 90 deg square corner. I think the mechanics of it will work out just fine, it's just the code part I'm wondering about.
warren57
Lochbuie, CO
Code in Colorado doesn't allow PVC above ground due to fire/smoke issues as stated by other members. I drilled my wall plates with 1-1/2" holes and left a few pull wires in place to pull circuits at a later date. You just attach to a (loose) pull wire, pull your circuit and throw the pull wire away. Probably should have 6 or so pull wires for future use?
6768rogues
Western NY
Our code refers to low voltage as "power limited" and is 50 volts or less. No conduit or enclosure is required. PVC pipe is above and beyond the minimum requirements in our code, so it is ok. We also use PVC electrical conduit, the gray plastic stuff. You might be able to rig up PVC conduit long sweep elbows by adjusting the diameters to fit. Or you could buy long sweep elbows, which are available for PVC piping.
PVC is combustible but it is not flammable.
Our code used to disallow PVC plumbing in commercial buildings but not residential. The plumbers' union kept it out for many years. The code was fixed a few years ago to allow PVC plumbing in all occupancies. PVC electrical conduit has been allowed as long as I can remember.
wssix99
Chicago, IL
You shouldn't use it because someone, someday, might install higher voltage stuff in there thinking that its kosher.
Steevo
43.49600, -112.04300
coaxial cable and Ethernet cable have minimum bend radius limits. I think a 90 degree elbow would exceed those for coax, IF you could snake the wire through it in the first place.
For straight runs, no problem.
BigJohn20
+1
It's the same reason why low voltage boxes are designed w/ open backs. For those curious, the TIA standards can be found online.
G
gumbudah
Northern Wisconsin
according to wikipedia, it generalizes bending radii for ethernet cables at 4x the diameter. Thatd be prolly about 1". 2" pvc sweeps should meet that just right.
venom50svt
Upstate Ny
Hmmmm, I have a question on that "plastic/pvc conduit.... I have a garage ceiling full of stray wires, I would like to organize them into something like that pvc... I see the 90 degree fittings are real gradual and I could snake the wires down the tube...
If it is bad, I take it is for underground use only??? Boy I was thinking of running romex stait through to the end and put a box on it... Hell my house just has the wire running through the walls and is just stapled,,,,:headscrat
Alchymist
Central PA
Why 6 or so pull wires? Just leave one or two. When you pull a new run, pull a new pull wire with it.
