Are the unions rated to the same pressure? I only need about 70psi.
Yes, the standard fittings are rated the same as the pipe they go on. PVC Unions have O-rings, making them really easy to seal as compared with common steel pipe unions.
I just came back from spending several hours at our rebuilt plant. We couldn't get any back flush flow out of one of the filter tanks. After quite a bit of time looking at valve positions, water pressure, etc., we decided it must be an obstruction in one of the back flush pipes.
We took apart a couple of the PVC unions on the 1-1/2" back flush line. To our total surprise, the check valve in that section was backwards! The nicely machined brass check valve body was marked with etched arrows which we carefully followed. Once we could see into the pipe, we realized that the etching on the outside of the valve was reversed! That along with the etched label: "Made In China!"
Two strikes against our supplier in the last week: Last Wednesday we were assembling the area where the new plumbing hooks into the old tank outlets. We couldn't get one of the new 2-1/2" galvanized ******* to thread into an existing female coupling. Once we gave up and got out from under the tank, we looked at the ****** in detail, fully expecting to find a damaged thread. Not so: The thread on one end of the ****** was left hand. Really difficult to see the tiny hash marks that delineate left hand threads!
To answer your original question, PVC unions are great so long as they are installed properly and protected from large external forces and the sun. And remember that we only use Schedule 80 pipe and fittings.
