How would a 2-roller slip roll work?
One is directly above the other and the more you tighten the roll down, by some molecular change that I don't understand, will curl the material. Same thing as when you take a pair of scissors and run a piece of ribbon through them to get the ribbon to curl. Same with a piece of paper. It will stretch or shrink one side of the material.
Without knowing the correct terminology, metal can be read to know what it will do if you work with it enough. For instance, in machining a piece of 3" wide, 6" long, 1/2" thick piece of aluminum using a fly cutter, and you want to cut it down to 7/16" thick. You clamp the piece of aluminum in your mill vise and start cutting it down on one side only, removing .062, that piece of material will curl up by maybe .010-.020 depending on the type of aluminum, when you check it on a surface plate.
If you would have another piece of the same material, and you start cutting it with a fly cutter and you take .031 off of each side, that material may be out by .001-.002 when checked on a surface plate.
Cutting the aluminum will change the molecules and pull them closer together on the side that you are cutting causing the material to bow. When you cut both sides, it does the same thing to each side and you reach a happy medium.
