Q: Rebuilding a ratchet head
guy48065
Calibration Lab
When installing a ratchet kit into the head casting the worst part is holding the ball & spring in the bore as the pawl is dropped into place to trap it. One kit came with a tiny spring steel "Z"-shaped tool but it's too flexible--or maybe some brands use stronger springs. The greased ball easily slides off a small flat screwdriver blade.
What do YOU guys use to hold that damn ball in place?
Pipe_guy
Northern British Columbia
I did two older snap on ratchets this week and it's a miracle I didn't lose a ball. I used a magnetizing tool on the spring and a little dab of grease on the spring. After that I just kinda used the pawl to hold the spring and ball down and push it into place. Took a few tries the first time but I got the second one the second or third time.
WWheeler
Middleofnowhere USA
+1
This is the tool you need. Here's a post of mine on a similar topic:
FWIW, The Snapon ratchet repair tool #SPP744 is invaluable to holding those ball-bearings in place while putting a ratchet back together. It's under $1 and Snap-On offers free shipping.
https://store.snapon.com/Non-Catalog-Items-RAT-REPR-TL-P9643445.aspx
Vantastic
Penns Woods
I can't afford that snap on tool so I made one out of a piece of sheet metal. It looks ****** but i fixed a bunch of ratchets with it.
gdocktor3
Connecticut
I took an old pair of tweezers, separated them and bent one half into a Z shape much like the tool. I actually bent the bottom side into a U shape so I can easily apply downward pressure with my thumb, while holding the ratchet. It has worked every time I've used it.
txlch
Before I bought the Snap on repair tool I used a pen clip off a random pen. Might have to take a few apart to find the right size clip but it worked great for me.
