Quality C-Clamps For Changing Brake Pads
expfcwintergreen
I bought about a 10 or 12 inch Craftsman C Clamp for changing brake pads but messed it up changing the pads on a 2009 Dodge Caravan.
How big does a c clamp need to be to work on sedans and passenger vans? Who sells good quality preferably American, Canadian or European c clamps?
jchetty
Central New Jersey
I prefer spending a few buck for the tool below. Cheap, reliable, and easy to use. I have used c clamps before this buying and in a pinch still will, but this one is faster, and is easier to apply more pressure to the piston..
Maybe not noticeably faster, but for $7 it is worth it. Most auto stores sell it as well
http://www.amazon.com/Lisle-24400-Disc-Brake-Spreader/dp/B0002SQU9K/ref=sr_1_1?s=automotive&ie=UTF8&qid=1407086117&sr=1-1&keywords=disc+pad+spreader
CJM8515
You messed it up pushing piston calipers in on a minivan? If it was truly very hard to push them back in then you have bigger problems. Ive used an 8" and a large set of channel locks before no issue. The ebay tool is nice and worth it, my buddy has one.
AndrewV
Fl
Was it a rear caliper, and was it a windback style piston?
Any larger c-clamp will work on a non windback piston.
Look up a speedy caliper depressor here.
A lang/kaster ratcheting. Piston depressor is my favorite. here.
ArtDeco
Dallas, TX
You messed up a C clamp changing brakes? You, sir, I want to party with :beer:
I had a Lumina w/rear discs that never did turn back in. POS brake system.
soloz2
Western NY
I've always used some cheap c clamps from HF.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Fedwrench
Valley of the sun
as others have mentioned, the brake pistons on a non integrated parking brake caliper shouldn't require a lot of effort to compress.:headscrat
There's a whole niche market in brake piston compressing tools. Some like the linked lisle squeeze tool is quicker than the lang tool linked. :beer:
MrJason
Bakersfield, CA.
Hit up a local pawn shop, since they've potentially got c clamp in on pawn, that they want to move quickly.
Older c-clamp mfgrs are your best bet.
jim1987
Umm
My Chinese 10" Irwin works just fine on the '84,'92,'96,'98 and ,'99 vehicles we have
383 240z
Findley Twp. Allegheny Co.
I vote "get the right tool" Here is the one I use:
There are different heads that go on it, so you can use it on rear calipers with integrated parking brake, large single piston, or smaller single piston calipers.
It's a little heavier duty than this one:
For dual piston calipers I had to buy this one:
Keith
jchetty
Central New Jersey
The Lang is nice. I was under the impression OP wanted something relatively inexpensive. I have a bookmark of brake caliper tools that are $$.
Are you doing front or rears?
Push backs are like this- hollow
Some rears are windbacks. Some look like this, some have like a cross. If they are not hollow center and in the rear, most likely windbacks
The following are all windbacks.
retrobuilder
Alpharetta GA
I just use one of the old worn pad (steel backing plate) as a push plate over both or the single cylinders and a apply force with a 6-8" F clamp.
Never have a problem plus stiffer than many of the tools.
Badattitude
I have that one and found that it's easier and quicker to just take the adapter off and use it with a 6" extension and 3/8 ratchet. No messing around with a couple wrenches
454ragtop
Carver, MA
Had one of those caliper tools as shown in the second post, not impressed, sold it. I find an 8" C clamp works much better, for the simple reason that here in the rust belt, you often need to use the clamp to get the caliper off the rotor. The ancient Cincinnati clamp I use, the swivel pad fell off, was going to put it back on, but found it actually works better as a caliper tool without it. Can often find these at flea markets or yard sales for dirt.
HTH, Jim
bczygan
DETROIT! Arsenal of Scrappers
I use the old inside pad and a woodworkers steel bar clamp that's laying around.
Sometimes I forget to loosen the cap on the master cylinder. That makes it much harder.
Jrsixx
Chicago burbs
