Is this thing on
Looking to add an exhaust fan to the garage, I rather explosion proof because of paint fumes and parts cleaner. it is a single car garage so it doesn't need to be a 5 foot monster.
Thanks
Thanks
Use a fan outside to push fresh air into the garage and then out through an exit vent. This gives you many options on type of fan you can use and it is not in the middle of those flammable vapors.
Even with an exhaust fan pushing air from the inside out, you still have air ingress from the outside coming in to replace that which was pushed out. Put some filters on it.
Marathon and Baldor(now ABB) are both quality motor brands often used in industrial applications. Most of the explosion proof motors the company I work for has in the exhaust stacks for paint booths are one of those 2 brands. There are various sources for the fan box/shroud/wall penetration, it really depends on how big of a hole you can put it and how concerned you(or your neighbors) may be with the aesthetics.
Be aware, there are different classifications of explosion proof motors, my expectation for what you're doing is a Class II, Group G will be adequate and kinder to the budget than a Class I/D 1 motor
https://www.worldwideelectric.net/articles/explosion-proof-electric-motor/
Thanks
You are over thinking it a tad. If fumes were of enough concentration to cause an explosion you would not care as by then you would be on the floor passed out from said fumes.
It's because of the fumes...It amazes me how a question develops so many tangents so quick.
