quality soldering iron
cheechi
Triad, NC
Not to be argumentative but that's where the operator comes in. You can get a good quality joint from a basic radio shack pencil. Even more likely with a Weller. That's where the operator comes in, you have to be able to recognize a cold solder and redo it or give it a few seconds to reach temp again/sponge off. No matter how good a tool, the operator has to be smarter than the tool. Period.
BirdMobile
Solder temperature is more important than most people think, but not as critical as many in the industry would have us believe.
I would solder a pair of connections, one with my Weller bench station set to the exact temperature based on the solder composition, and another using the rudamentary temp control on my Portasol bhutane iron based on past experience using that tool. I would DEFY anyone here examining both to tell me which connection was made with which iron.
Again, it's not the tool that really matters... it's the skill, experience, and knowlege of the person using it.
Monkey Milk
Hawaii
for mobile I like my ultratorch, gets hot fast and I can control the heat. Not like the cheap butane ones, also has a ceramic cone and it has different accessorizes for tips.
merbie
england
Iv been using my weller 75 watt for a few years you could weld with that thing
Sent from the sticks
Contract_Pilot
Vancouver, WA
cheechi, I will agree that even with the proper tools it is how they are used. Proper Use and understanding is a must! "I am assuming that-guy is learning due to the nature of the post" It is better to learn with the proper tools vs. having to waste time, money, quality of end result. I am sure if he is building a wire harness it wants it to last and also look good! Proper tools will save him a lot of frustration in the long run!
BirdMobile
cheechi, I will agree that even with the proper tools it is how they are used. Proper Use and understanding is a must! "I am assuming that-guy is learning due to the nature of the post" It is better to learn with the proper tools vs. having to waste time, money, quality of end result. I am sure if he is building a wire harness it wants it to last! Proper tools will save him a lot of frustration in the long run!
Indeed.
Bench station with temp control (preferably analog, IMO) is the best way to start out.
exmaxima1
Midwest
Don't forget QUALITY SOLDER. I've been soldering harnesses for many many years, and I refuse to use **** solder. If you don't have to use lead-free or mildly activated flux, DON'T! Get some Kester 44 w/66 core flux and you will be golden.
exmaxima1
Midwest
Contract_Pilot
Vancouver, WA
And get multiple diameter's also for the AWG of wire you are soldering. General auto wire about 14awg or Smaller should not be using any solder with a diameter larger than .031 I had a cheat sheet some place for wire size and optimum solder diameter for the kester brand. It is in their data sheet if i recall! Also need a silver chromate low resistance if soldering to any Fuel Injection or Ignition areas that wire resistance is critical. I believe kester it is 285 or 282 I have a spool of .010 or .015 on the shelf for the tiny 22awg Low R EFI wiring i fixed for a friend.
BTW, That-Guy what is the harness For?
Went and looked on the shelf it is Kester 275 .020 Low Corrosion, Low RES, No Clean about $100.00 a LB if I recall.
Contract_Pilot
Vancouver, WA
T
that-guy
NoVA
lets try to keep this going. this is a very good discussion going on in here and some really good tech advice
kiatech
Toledo, Ohio
f575gtc
Soldering stations are nice and all when you are soldering a harness or board on a bench. I would not use one when I am inside a wheel well of a car soldering a wire, or upside down under the dash. I need something portable and "wireless"
Contract_Pilot
Vancouver, WA
That-Guy have you looked in to Tefzel Wire "mill spec wire" if it is for a wheeler, bike or something that wires can be exposed to the elements.
My Friend of mine did his harness for his jeep in Tefzel yea, he works at an avionics shop so he labeled every wire with a corresponding number to his diagram for easy diagnosis final results was a very clean install. It was over kill! But hey depending on what the harness is for over kill is good.
The Teflon insulation is nice and strong and compared to vinyl automotive or gp grade wire.
T
that-guy
NoVA
that-guy, did you see my post about what you are using the harness for?
I'm building an engine harness from scratch for a standalone system, and I am modifying my body harness for up to date lighting and hiding the wiring as best as possible
Contract_Pilot
Vancouver, WA
That-Guy Another bonus with the Tefzel or Mill Spec wire is you can order how ever many conductors 2,4,6,10, Etc. so when you have a run of multiple wire you have a nice clean bundle with additional insulation for protection. For the ignition and stand alone FI you can get shielded wire. Also check out the heat resistance of the Insulation the stuff don't melt like vinyl.
Some Links.
http://www.aircraftspruce.com/categories/aircraft_parts/ap/menus/el/wire.html
https://www.prowireusa.com/c-32-m22759-16-tefzel-wire.aspx
T
that-guy
NoVA
Some Links.
I've already got all of my materials and such as per the instructions of the guy who built the ECU and will be tuning the car, everything is shielded and will be covered with Reychem and put through a D38999 connector in the wirewall, just trying to nail down a good soldering setup now
GSEninja
I really like my Hakko FX-888D, I bought this and my third hand from adafruit.com... prior to this I had a Radio Shack unit, not bad but the Hakko is far superior
http://www.adafruit.com/products/1204
Specs pulled from page
65 Watts
Ceramic Heater
Temperature Range: 120° - 899°F (50° - 480°C)
Temperature Stability: ±1.8°F (1.0°C)
Temperature Control: Closed-loop sensor
Dimensions: 100(W) x 120(H) x 120(D) mm, 3.9(W) x 4.7(H) x 4.7(D) in.
Weight: 2.6 lbs (1.2 kg)
ESD Safe: Yes
IPC J-STD-001: Meets or Exceeds requirements
900M-T-1.6D 1.6mm 'screwdriver' tip
For use in 120V countries only
UL Approved
madcrisis
65 Watts
Ceramic Heater
ESD Safe: Yes
UL Approved
I just got one of these. Havent done much soldering but this thing heats up fast and maintains the tmeperature well. Puts my old POS radio shack iron to shame. Very high quality. Im ecstatic to have it for years.
PBCampbell
WV
I don't really do anything much related to electronics, at least nothing so heat sensitive that I've felt the need for temperature controlled irons. I have a liking for old style industrial irons like American Beauty and Hexacon. My favored irons are a bent style usually described as "hatchet" style or "Ergo". I'd suggest checking out the websites for those brands as there is some good information on them, particularly American Beauty.
