Quality tire gauge--recommendations needed
BrandoJames
Tornado Alley
Right before the lockdown, I bought a Rigid pancake air compressor. But I've lost all my tire gauges except one. Anyone have a recommended tire gauge. I'll probably buy two, a quality gauge to keep in the garage with my compressor, then another that's good quality but lightweight to keep in a vehicle. Thanks in advance.
Gummi Bear
Sunset, Texas
I have Milton.
This is what I keep in the truck https://www.miltonindustries.com/ga...-large-bore-dual-chuck-80-1100-kpa-0-8-11-bar
10 ply tires, I need the higher pressure gauge
In my toolbox, I have one of their basic pencil gauge. I’ve had it since I was a teenager
I also have one of their inflator gauges
Looks like this, I cannot remember the part number off hand tho
https://www.miltonindustries.com/gauges.html/large-bore-dual-head-inflator-gauge
For the quads, and other stuff that uses low pressure tires, I have a 0-15 gauge with deflator
https://www.joesracing.com/product/joes-tire-pressure-gauge/
I went to the woods because I wished to live deliberately...
Henry David Thoreau
dnschmidt
Phoenix, AZ
I'm with Jeff on the Astro for one significant reason. Not only can it put air into your tires when you push the lever all the way down. It will also release air from the tire if you only partially push the lever. This way it's easy to get exactly the pressure you want from one hook up.
humpty
Minneapolis, MN
I bought the Topeak Smartguage for mtn bike use but it is become my go to gauge for everything at this point.
It seems accurate, has great battery life, can do Schrader and Presta and goes up to 250psi.
humpty
username2
Just to throw my hat in the ring of people-who-recommend-the-thing-they-own, I've been really happy with my Moroso 89550 tire gauge after being angry at a few cheap ones. No doubt made of the purest Chinesium but not a bad product, at least as of ten years ago.
zmotorsports
Northern Utah
My "go-to" tire pressure gauge and chuck is my Blue Point TPGDL1000C. Accurate and quick.
My pressure gauges only without filling option but with hose are Haltec. I have two of them. One in the standard pressure and one for low pressure powersports equipment.
IMStuner
I have a motion pro and joe racing. The motion pro cost more but the Joe racing is good bang for the buck.
M6erfan
'Merica!
I just need a couple of pressure gauges, thanks.
I've had my Longacre liquid filled 0-60psi gauge for about 8 years. No complaints, though it does read about 1 lb. low, but I'm aware of it so it's inconsequential. It has been very consistent.
n8n
Curtis Bay, MD
I use Longacre because that's what my local speed shop sold, but they appear to have gotten significantly more expensive since I purchased them. The inflator is real nice though.
TheLoamRanger
Hobart, Washington
I have a Joe's gauge that I really like, except that it doesn't read right anymore. I liked it enough at the time that I bought one for my dad. Well, something happened to mine and it now reads low. I take good care of my tools and don't remember ever dropping or bumping it. My dad's still works great. I love the instantaneous readings (rather than needing to "release" the reading) and the ability to push the button to deflate. You can over inflate and easily bring down to pressure, monitoring it the whole time. Quick and easy.
I've never had a bad experience with anything Milton (all of my couplers and some inflators). If Milton has a similar gauge to Joe's, I may try that out for my next one. Otherwise, a new Joe's will probably be in my near-ish future.
bobg03
conway sc
I have one that I purchased thru cruztools, with a hose a gauge and a bleedoff. It has proven to be accurate, durable and reasonably priced.
matt_i
Yeah, the long high pressure Milton for duals.
I got a glow-in-the-dark Intercomp pressure gage for vehicle tires. But that's going to stay in the shop and not in the car.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I like Milton stick gauges, made in the USA and every one I've had reads the same. And I prefer the dual head straight foot style, but each is available with the "standard" or angled dual head as well. For general use and carrying in the vehicle, it is the S-929, 2-120 psi. For heavier duty use, I really like their long field service gauge, and the newest model is calibratable. It comes with the small calibration tool to make adjustments. The black "stick" is aluminum, and reads 10-160psi.
RKA
I’ve given up on analog gauges. I have an intercomp, longacre a cheap HF gauge, all are off by 2-4 lbs now. They all sit in my garage toolbox, couldn’t get handled more gently. I know they can be adjusted, but I don’t want to bother with that periodically.
My motion pro digital has been consistent and accurate going on 8+ years. My gold standard is a pencil style with the little sight glass, but it’s a PITA to read, so I use it only to make sure the primary gauge I’m using is within a lb. And these days I use a cordless Dewalt inflator, set the pressure and go with what it’s digital gauge reads. It’s within a lb, good enough for me.
For the glovebox, I just drop a pencil style gauge with the sliding scale. It’s compact and no batteries, so it will work the one time in 15 years I reach for it.
