Yes, I expect that the tool will break, well, replace it. And of course for every clip there is a proper tool and proper procedure to remove it, obviously it won't last 20 times but it will last 10-15 if removed correctly.I can't begin to tell you how many of your plastic tools I have broken and had to replace on my dime trying to get push pins and different plastic clips/panels off without damage. There is no proper tool, you use what works without damaging the surrounding panel.
As far as I'm concerned most of them should be a one time use part.
If you are willing to be without your vehicle for another day or two while the mechanic waits for the new plastic clips to come in I'm sure they would be happy to replace them.
For example, SMA didn't know that you can very easily remove some clips with a 7 or 8mm socket, push it boom, removed in 2 seconds.
Posted in the comments
