BurtEggley
- Joined
- Oct 8, 2024
- Messages
- 912
Anyone put quartz, stone, Corian, Caesarstone etc onto a well made acrylic type shower pan? Talking 600 lbs total spread out over the pan tiling flanges.
yes, thank youInstructions for shower bases usually indicate to keep the wall material up off the base for drainage.
thank you. I looked at their site and only saw an acrylic unit in our size. Could not find their ratings so just guessing it is designed to the same ANSI ratings as ours. Since the tests are not destructive, one only knows that the minimal ANSI tests have been made, and not the actual point at which it fails.Also check out MTI shower pans:
Custom Shower Bases & Pans | High-Quality Shower Solutions
Shop custom-made shower bases and pans for a perfect fit. MTI Baths offers durable, custom shower bases designed to enhance any bathroom space. Check today!mtibaths.com
thought I would close this out. The Corian was installed today. We used shims that will come out in a few days so there is no load on the pan.
The shower pan is in the right hand photo with all the shims. They will come out and the weight will be on the wall. It will have grab bars, and a shower door that is screwed to the wall thru the Corian, so they will help anchor it mechanically. I think the original post was whether the 620 lbs of Corian Quartz would crush the pan or not.That's not a shower pan....
Looks nice though
