Quartz Floor Layer Correction
biljohns
Advice Please...
I ran out of clear epoxy putting down a layer of quartz. I was not able to make it to the final portion of the garage. What is the best way to correct the issue in the picture?
What I am thinking...
Taking my oscillating tool along the high spot edge and sanding down to make a smooth transition. The next layer of quartz will cover of the sanded spots. Good idea?
LegacyIndustrial
deerfield, IL
It will show through to some degree. I would get more epoxy, seal the areas you missed first, then proceed.
Armorpoxy
You can try feathering out these areas with a hand grinder, and re-epoxy again with a thick coat of clear squeegeed out with another layer of quartz.
