Question about a Wilton 6in vise
Tarnished
SW Ohio
Evening all,
CL pick up today on this vise and seeking a little info. This is a 6in vise which I believe to be made by Wilton. Cheesy stick on Wilton label is only ID I can find to confirm this. Date stamp on bottom is 2 - 88 which, I believe, should mean the vise was manufactured in February of 1983. 5yr prior to its warranty expiration of 2 -88. Correct? Where was this vise made? Anyone know for sure? Can find no PO at all on vise. Stick on Wilton label only shows corporate headquarters address I believe. Was this still produced in the USA in 83"?
I find the vise to be in good shape overall. Has a few scrapes and bruises normal for its age. A couple of welding hickies that will file off, but all works as should and threads in good shape. Nothing broken or welded. Jaws in good shape, but could possibly use a new set. It does have the pipe jaws that are held in with 1 allen screw, and one is broken. I am thinking I should be able to find parts for this still. Anyone know a reasonable place to find them?
Overall I am pretty happy with this guy and the plan is to mount it on a pedestal for my main go to vise. Have to make a new mounting plate for the 4 hold Wilton to replace the 3 hole that is on the pedestal now. Will post up pics when I get it mounted.
I Will go off now and search and see what I can find out about this vise, but any information you all care to add will be much appreciated.
Thanks
John
alex71
SE Florida
Wilton tradesman vise. Us made,useless pipe jaws, as evidenced by the broken jaw on yours. Replacements are readily available, but will break again with moderate use.
Not a bad vise overall. Biggest deficiency IMO is the height of the jaws.
T
Tarnished
SW Ohio
Thanks Alex,
From what I am able to dig up I believe this "tradesman" to be model 1760. Parts can still be found if pockets are deep enough. Would like to replace the pipe jaws, is there anything I can do to make the pipe jaws last better, or should I just take them out and forget it? I will get it cleaned up and scrub off the crud, re-grease and put on the stand. Then it will become my main beater, and I won't worry about chipping the paint. :lol2: It will have a good home, and as you can see from the pix, I'm a little vise obsessed any way... :lol2:
alex71
SE Florida
Maybe you can have them machined out of steel. The cast iron pipe jaws are too small, which is why they break.
Provincial
Near Salem, OR
I have found that it is more practical to have a small pipe vise around rather than use the ineffective pipe jaws on a bench vise.
I would toss the pipe jaws from the Wilton.
T
Tarnished
SW Ohio
Thanks Guys,
Appreciate the info. I certainly have other vise's around to use, and in fact I have a small old bench pipe vise that works great. Guess I will use it if I need to clamp pipe. Still to complete the resto, I will be looking for a new set of jaws for this one. Machined steel is good idea. Anyone know a source?
Are all the Wilton pipe jaws junk? Or is it just this particular model? I know there are several styles, which ones are good/bad? Hadn't heard anything bad about them, but hadn't checked either.
