zak77
Ok so this isnt about my garage but about my master bedroom closet. The closet is about 5x6 and sits at very back left corner of my Ranch so 2 of the walls of the closet are exterior walls. It's not heated except for whatever heat makes it way in there from the bedroom. My issue is when it gets below about 15-20° outside i can see condensation forming on the interior drywall of the exterior walls, but more on the side of the house with the eaves. So, obviously that wall in particular is getting too cold. My house was constructed of 2x4 exterior walls with fiberglass batts, vapor barrier(not mentioned earlier), along with 3/8" Faced Polystyrene on the outside of the plywood sheathing.
So far i've installed a floor vent that went down into the basement trying to get some air movement, didnt work all that good, put a vent above the door so more air can move but that didnt make much of a difference either. So without tearing out the drywall, using spray foam then re-drywalling i was contemplating what if i put 1" XPS foam board on the existing drywall for the 2 exterior walls then put drywall over that. I already have r-38 cellulose in the attic however given that the house was built in 1990, i'm sure it's the lack on insulation directly above the top plate that isnt up to snuff. I'd also like to put XPS and foam around all the proper vents up there but that's on the list for sometime in the future.
So is putting foam board over drywall then putting drywall over that asking for issues?
