rockcrawler
In the diesel performance world we coil the copper tubing going from the exhaust manifold to a sensor to allow the air to cool before making it to the sensor. This minimizes the chance of the sensor being damaged by the heat. Would this be a viable solution to cooling the air coming from the compressor to the air lines? I don't need a cooler or drier considering that I will very rarely use air tools.
I just purchased the RapidAir 3/4" Maxline kit and I'm trying to figure out the best way to run my system. I have a detached garage where my compressor will be located and my air line system will be located in my attached garage. There is a flexible air hose that runs underground through a PVC conduit that runs air from one garage to the other. I plan on putting a regulator and water separator inside the attached garage where the line comes in from the detached garage. Then I'll run my system from there. I also plan on doing a loop system with one drop on the left side wall, one drop on the front wall and one drop on the right wall. I've read a lot on GJ about running the air lines and it seems pretty straightforward except for all of the differing opinions.
