Hi I need an 8' 5" beam for a 1/2 ton pull trolley. What size beam should I get? Thanks
M mkjrcc New member Joined Jun 17, 2012 Messages 3 Jun 17, 2012 #1 Hi I need an 8' 5" beam for a 1/2 ton pull trolley. What size beam should I get? Thanks
K kbs2244 Well-known member Joined Nov 11, 2006 Messages 14,065 Jun 17, 2012 #2 eight foot five inch span? One thousand pounds? I have seen that done with barn door track. I would think a three inch beam would be plenty.
R rslaback Well-known member Joined Jul 24, 2010 Messages 4,086 Location Westcentral Wisconsin Jun 17, 2012 #3 Check to see what the narrowest your trolley can be set to. Then get that size or slightly larger.
B BD1 Well-known member Joined Mar 18, 2007 Messages 4,602 Location north side Jun 17, 2012 #4 Here, check this out. http://www.wallacecranes.com/ What's your location ? Last edited: Jun 17, 2012
3 318fekim Well-known member Joined Mar 12, 2012 Messages 312 Location Seffner, Florida Jun 17, 2012 #5 Ask your steel supplier about drops...with that low of a capacity & only needing that length you should be able to get a deal.
