So I got a 1995 Chevy 2.2L S10 in my shop that isn't running correctly and I am by no means a chevy expert. It has an OBD2 port but none of my scanners will communicate with it.
When I first got it it would not run but after messing with it a bit I got it to run (badly but running).
It has spark and according to my testing its decently strong spark. I also checked timing (I marked spot in crank at TDC) and used a timing light to see if it was atleast in the ballpark and it seems to be around 10degree BTDC that its igniting the #1 cylinder. So timing and ingition seem to be reasonable so I did a compression test and it did 180psi on all 4 cylinders. So now I am pretty suspicious of fuel mixture and given my lack of experience with the GM product I came to a few conclusions on what controls mixture.
1. MAP Sensor (Working correctly I did voltage vs vac test)
2. Engine Intake Temp Sensor (Working correctly res vs temp test)
3. Engine temp sensor (gauge and ECU) and also getting good results from testing. However, I did shotgun a part at it since it was only $14.
4. 02 sensor but clearly not going to have any effect on startup.
5. I also checked voltage output from the throttle position sensor and it seems to be alright.
So, I cleaned the throttle body and checked the idle motor and all ports are clean and motor is working what seems to be correctly.
The truck will idle decently with a few stumbles but will not take throttle.
However, if I open a vac leak the truck runs way better and will even take a bit of throttle. Also, if I unplug the map sensor from the engine and pull vac on it to lean out the mixture the truck runs pretty damn good. So I tested vac in the manifold and its a lousy 5inches of vac. So now I am thinking vac leak at the intake manifold.
My real question is does any scanner work with this 95 truck?
