air cooled
Building a pole barn this winter and I have a question.
I cut rigid closed cell foam panels to fit between the exterior wall girts and sprayed the small gaps with closed cell spray foam.
We are now going to put fiberglass insulation blankets in between the poles and i'm not sure if we should put a plastic vapor barrier up before we install the interior wall steel or consider the closed cell foam panels and exterior wall girts the vapor barrier.
So, the layers from the outside in are:
Exterior Steel -
House Wrap -
Closed Cell Foam Panels & wood wall girts -
Fiberglass insulation blanket -
(plastic sheeting vapor barrier?) -
Interior wall girts -
Interior Steel
View media item 65496(sorry, dont know how to rotate photo)
Thanks
Exterior Steel -
House Wrap -
Interior Steel
Thanks
