I have just finished installing the supply line in my shop, used 3/4" line from Maxline. The process was ok, took me about 2 days to complete the install.
There are a total of 3 outlets, 2 are connected to 50' reel, 1 has a quick connect on. there are 2 Tees total. Total line length is about 55'.
Now, after the install, I let the system charge until the compressor shut off at 157PSI. I turned it off and left it that way for 20 hours. After 20 hours, the pressure gage on the compressor shows 70PSI.
Is that too much of leak in my system? I guess at this rate, my compressor would kick in every 7 hours. I suppose it's ok to let it run once every 7 hours, or is that too much leak.
. Use a decent sealant and be careful with aluminum.
