question about costco/sams led lights
1slow62
Florida
I haven't purchased them yet but had a question about operation. I'm looking at the led strip lights with the 3 position pull string. The ones that can be linked up to 10.
The way I want to run them is all 10 linked together and set on the brightest setting. Then plugged into a switched outlet.
My question is if I switch the power off do the lights default to off or will they come back on in the last setting when the outlet is powered on?
Chucktin
I bought 4 from Sam's. Have yet to plug them in. Was wondering the same. For my situation they will be on a switched duplex outlet by the shop door. Previously I had 4 floresents that all came on off one switch and pulling 4 chains will be PITA but I can manage.
FTG-05
TN
I have 14 of those Sam's Club 4' shop lights. Four have the proprietary linking connector, the other ten have the standard 3 prong 120 vac connector. All are on one switch. All go one when I hit the switch.
None of them are connected together, too far away from each other. All are connected to a switched outlet.
tom-ky
Morgantown, Ky
Sam’s lights with no frost lens..........still a deal killer.
Why does everyone say that? Most LED's that are in industrial settings are not frosted, talked with an electrician Friday about LED lights and they dislike the frosted ones.
I am in lots of factories and warehouses and yet to see any frosted ones.
FTG-05
TN
None of mine are frosted. I wanted light, hence, I bought lights that put a lot of lumens out.
Glare: Not looking at them, could care less.
Hot spots: what hot spots?
Uneven light distribution: That exists in my shop, but that's because of where I could get my tractor to work at heights.
Much ado about nothing.
1slow62
Florida
^^^^ exactly. I will be putting these in a 30x30 shop with only 2 10x10 doors. I need a lot of light. Building hot rods i need to see what's going on....
Showkey
"MEMBER EMERITUS"
Wausau WI
If that’s your criteria.........then a couple for 10,000-20,000 lumens lights should do the trick.
1slow62
Florida
The problem with only a couple is placement. Having 2 lifts in the shop with cars on both really cuts down on light. With 10 i have more options. I am also going to hang several old 4 bulb 3' florescent lights that have the ballast removed and no-ballast led lights installed. These will be mounted on the walls.
Showkey
"MEMBER EMERITUS"
Wausau WI
It was sarcasm 10-20k lumens fixtures are the ultimate hot spot and uneven light distribution ............the no frost, hot spot and more even light distribution topic has been so beat up that the lighting experts on the forum likely will not comment.
Fixture Lumens is one measure of light at the fixture ........even LUX ( light measure at the work surface) distribution over the work surface at that surface might be the entire shop or top of a work bench far more important.
CJ7VFR
Central New Jersey
Thanks ftg. That's what I was looking for.
I also have the Sams Club Multi Mode LED shop lights in both my garage and basement. I bought the 10 pack when they had them for sale a few months back.
In my garage, all are set to the highest lumen level. In my basement I have most of them set at the highest lumen level, with a few set at the middle lumen level over the washer and dryer.
They are all controlled by light switches to turn them on and off just like regular light fixtures would be. Whatever light level you set them at via the pull chain will be the light level they come back on to when you shut them on and off via your light switch on the wall. The only way to change that is to turn the lights on and pull the chain to put the lights into the lumen level you want. Once they are set via the pull chain, that is where they will be.
I love these LED lights for the fact that they are instant on and instant brightness, no fluorescent "hum", the ease at which they can link together, and the fact that on sale they cost just $19.00 each.
My garage and basement are much better places to work now that it is much lighter in these areas. Also, the fact that they are multi mode, and you can set the brightness that you want/need for any given space/task makes them worth it to me, even though they do not have frosted lenses.
I will say that the only two issues I have with them so far is that they due tend to make a bit harsher shadow on things than the old fluorescent lights did. And if you look right into the LED's you will see little white dots for a few seconds.
But once you learn not to stare directly into them, like you learned not to stare directly into the sun on a sunny day when you were a kid, then that second issue becomes a non-issue after about a minute.
Jim
JerryC
Memphis TN
If you work under the hood a lot, this might be a good idea.
Angle the fixture to shine under the hood. I put two of the 4' twin tube LED's 10' up on the front wall angled so that they shine directly into the engine compartments and they are high enough up that they won't bother me just moving around the garage.
1slow62
Florida
Just an update. Installed 10 lights and they do stay in the last position of the chain pull. Worked out great.
