question about hookin up a welder?plez need help
coorslight
so i picked up a miller 180 autoset for a smokin deal, and i have a couple questions about hooking it up. ive leaned how to weld just not the hookin it up part, so my questions, im wanting to welding at home but all thats there is(1) AC at the wall but i need DC for steel, do i need an power inverter? or is it built in the machine? also im having a buddy string me a 220 line to a part of the house im going to weld at,(2) will a 30A breaker work if not what do i need?(3)i also have a troy-bilt 5550watt generator and im wondering if that will power the welder when we have to go out and fix the tractors. ill attach pics of the welder specs and the generator specs. thank you for helpin out.miller 180 specs.jpg
Sparkfarmer
Toronto Canada
1) 220 VAC directly into the machine
2) 30 amps on your 220v outlet should be fine as the welder will draw 21.7 max
3) thats a 5.5Kw generator to run a 4.1Kw welder... should work
